Solution
Ivan Andrieiev
How to make the "Solution" field mandatory when closing a task?
4 accepted
Nic Brough -Adaptavist-
September 29, 2022
Add a validator to the "close" transitions in your workflow, they can check if a field is filled or not and prompt the user for more data
Ivan Andrieiev
 @Nic Brough -Adaptavist-  Hi
Sometimes when closing the task, there is no window with filling in the "Solution" field. Just switching to "Closed" status.
September 29, 2022
You'll need to talk to your admins - they will need to add the screen (or the field to the current screen) in the workflow, so that the user is prompted for it.  Or just the validator I described.
Giuseppe Barnaba September 29, 2022
you could create a closure screen to insert between the status.
You could add the "solution" field in this closure screen and you could add a "Field Required Validator" validator in the workflow between the status.
John Funk
Hi @Ivan Andrieiev
You can add a transition screen to the transition going to Closed and place the Resolution field in that screen. Then add the validator to the same transition as Nic mentions.
Jimi Wikman
Do you want to block the transition if it is not filled in?
Do you have that field added to the close screen?
