Solution
Ivan Andrieiev
How to make the "Solution" field mandatory when closing a task?
4 accepted
Nic Brough -Adaptavist-
September 29, 2022
Add a validator to the "close" transitions in your workflow, they can check if a field is filled or not and prompt the user for more data
Ivan Andrieiev
 @Nic Brough -Adaptavist-  Hi
Sometimes when closing the task, there is no window with filling in the "Solution" field. Just switching to "Closed" status.
September 29, 2022
You'll need to talk to your admins - they will need to add the screen (or the field to the current screen) in the workflow, so that the user is prompted for it.  Or just the validator I described.
Giuseppe Barnaba September 29, 2022
you could create a closure screen to insert between the status.
You could add the "solution" field in this closure screen and you could add a "Field Required Validator" validator in the workflow between the status.
John Funk
Hi @Ivan Andrieiev
You can add a transition screen to the transition going to Closed and place the Resolution field in that screen. Then add the validator to the same transition as Nic mentions.
__ Jimi Wikman
Do you want to block the transition if it is not filled in?
Do you have that field added to the close screen?
