Sometimes re-index does not work
Stefan Stadler
August 12, 2024
Hi all,
I am running a bunch of listeners, where different kind of automations happen.
One common example is, that after updating a custom field, there will be further updates depending on what has been updated. Those happen in the listener and at the end, the script performs an update.
Unfortunately, it appears that this index is not always working.
We have seen several times, that the index had to be run manually afterwards for the related issues to appear in the JQL results.
I am using the following code for indexing and I am not sure, what is missing that causes this behaviour. Can you let me know, why indexing is sometimes not working and sometimes works like a charm?
Thanks!
IssueIndexingService indexing = ComponentAccessor.getComponent(IssueIndexingService)
boolean wasIndexing = ImportUtils.isIndexIssues()
ImportUtils.setIndexIssues(true)
indexing.reIndex(issue)
// This is only for logging. I could therefore confirm that the indexing really has been running.
//jLog.debug(step, "Reindexed issue ${issue}. System was indexing: $wasIndexing")
ImportUtils.setIndexIssues(wasIndexing)
Fabio Racobaldo _Catworkx_
Hi @Stefan Stadler ,
I have several script that need reindexing and on my side I use just IssueIndexingService
indexing.reIndex(issue);
 Did u try this code only?
Let me know,
Fabio
Stefan Stadler
February 23, 2025
Hi Fabio,
yes, as you can see this is the exact same code as you are using.
SERVER
VERSION
9.4.1
