SonarQube Connector for Jira is not work
lvzhongwen
June 21, 2020
some error:
No data found. Check your project settings and the connectivity between JIRA and SonarQube server.
Configuration:
微信图片_20200622135746.pngcan i get some help?
Antonio Calero June 22, 2020
Hi Ivzhongwen!
It seems that your SonarQube URL is a "private network". Could you please confirm that the ip is reachable from your Jira server?
You must check your resource key too because it doesn't seem to be a SonarQube "project key", it seems to be a sonar property.
Best regards.
苏仁
June 22, 2020
Can you teach me how to find resource key?tks
Antonio Calero June 23, 2020
You can find the resource key on the right side of your project space along with a "copy" button:
If you are using SonarQube 8.x or later the right side bar is hidden and you must click on "Project Information" on the top right to get the same information:
Best regards.
苏仁
July 23, 2020
tks
