I want to migrate a specific project between Jira clouds. I exported a CSV and tried to import it, but got an error. Also, I am unable to open the error log file. As an alternative, I thought about exporting a Zip file from a Cloud backup and importing it, but have not been able to do so because I am concerned that it will overwrite all the data in the destination. I would like to know if there is a better way. Translated with DeepL.com (free version)
Hi @森橋勇太 ,
You’re right to be cautious—both options have some big limitations.
Here’s what to know:
If you want to move one project cleanly, you may consider OpsHub Migration Manager (OMM), Atlassian Solutions Partner that can help you:
Let me know if you’d like a pre-migration checklist or a dry run setup—it’s a safe way to test the move before committing anything live.
Hope it helps!
Hi @森橋勇太
You could also consider using this https://support.atlassian.com/migration/docs/perform-a-cloud-to-cloud-migration-for-jira/
It's a Cloud-to-Cloud migration tool for Projects.
Hope this helps
Hi @森橋勇太 ,
To move Jira projects from one Cloud instance to another, please refer to the community discussion below, which should help you with the process:
Geethanjali
