Specifying an issue resolution transition condition?
Alister Cordiner April 2, 2014
I have created a Jira transition called "Abandon Issue". I would like this transition to be used for closing issues with any resolution other than "Fixed". I have added the following transition condition:
The field Resolution will have to be not equal to value 'Fixed'. Compared as String.
However, it's not working. When I click the "Abandon Issue" button, I can choose "Fixed" in the issue resolution screen and the issue transitions to "Closed" without any error messages. What am I doing wrong?
It turns out what I was looking for was a transition validator rather than transition condition. I just had to install the Script Runner add-on and then create a script validator like this:
issue.resolution?.name != 'Fixed
Nic Brough -Adaptavist-
April 2, 2014
Yes, a Condition stops you executing the transition, and works off current data before the transition starts. So it always passed your code because the current resolution was null.
Another option would be to not ask the user for a resolution - instead, use a post-function to set it to "abandoned" or whatever the most appropriate resolution is.
