I imported data from RTC, after I imported the data, in big picture the sprints are displaying in the Summary which contains the Project Name and assigning a key to the sprint.
I am not sure why an Import would cause this problem.
In the Gantt View the Sprint is displaying as below:
Key Summary
81 Sprint 26.5
These 2 columns display the Project Key and Project name
Why is the Sprint displaying in the columns for Project Key and Project Name? Why is a key being assigned to a sprint?
How can I fix this, there does not seem to be a way to remove these entries.
Hello Nannette
You could have Sprints checked in the Scope definition of your BigPicture program, as depicted in the screen capture below, and this might cause Jira Sprints to appear in the left, work breakdown structure pane of the BigPicture's Gantt chart module.
