Starting customizing JIRA
bogdan_maier February 25, 2014
Hello I have been requested to do a demo for a jira plugin.(I think that's how it's called ). I have nerver worked on Jira dev, and I'm a student also. How can I start working for this demo, is there a free way? Since I am completly new I have no idea how to start this any advices or useful links are highly appreciated
Nic Brough -Adaptavist-
February 25, 2014
Start with https://developer.atlassian.com/display/DOCS/Getting+Started
Very briefly though - download the SDK and do some reading - the SDK lets you get stuck straight into coding, and one of the (many) nice things it does is provides an entire environment. Once you've got it installed, you can run one script to create a plugin skeleton, and then immediately run a second script which will compile it, build the plugin, download the target version of Jira, install it with some basic starting data, run it and enable your plugin.
Thanks a bunch, helps a lot. Now lets start descover JIRA :D
