Story Points for Epics - Difference Between Advanced Roadmaps/Plans and Issue
Luiz Henrique Aquino Silva
July 15, 2025
This Epic is an example but this is happening with several Epics. I set the Story Points (Story Points Column) inside/using the Plans/Advanced Roadmaps and the Story Points Field inside the Epic is not being updated with it. You can see that this Epic on Plans has 40 Story Points (Story Points Column) and inside the Epic only 30 Story Points (Story Points field). Does anyone know why this difference? Are these 2 different fields? Thanks!
Advanced Roadmaps/Plans:
Epic (Inside the issue):
Trudy Claspill
Hello @Luiz Henrique Aquino Silva
When you make a change to issues in a Plan that does not immediately update the corresponding issue. You need to click the button in the upper right corner to review changes that were made in the plan and select the ones that you want to commit to their corresponding issues
Did you do that step?
PM_이유경
If the issue is that story points are not being rolled up (summed), it can be resolved by configuring an automation rule.
In our case, we’re using the Standard plan (though I’m not entirely sure if the plan level affects this behavior),
but we were able to resolve it by setting up an automation to sum the story points accordingly.
