Sub groups of jira-users not importing into JIRA
Andrew Riley February 12, 2013
Hi There
I have set up our dev JIRA with ad integration with Microsoft Active Directory and all going well so far. Only issue I have is that the sub groups that I have created in jira-users are not being imported. All groups are under the same OU which is JIRA. I have worked through with Chris on other related issues.
I am trying to add in sub groups into jira-users rather than each individual person. We have about 800 people working at our company and most of them are already in the right groups but not yet added into jira-users.
Andrew Riley March 5, 2014
Hi Ahmad. I managed to understand how this works from Atlassian as you suggested.
Thanks, Andrew
AhmadDanial
February 17, 2014
Hey there, Andrew.
I noticed that it has been a while since you receive any response here. Have you raised a ticket in the following link:
https://support.atlassian.com
You will be able seek help from the support engineers regarding the questions that you have here. If you have not, I would kindly suggest you to do so.
Hope this helps and all the best.
