Sub-tasks are not visible in a classic business project
Ankit Chouhan August 13, 2020
I have created a classic business project. When I am creating a task, I can see that on the board. But when I am creating sub-tasks within a parent task, I do not see those sub-tasks appearing on the board. Although those sub-tasks are visible inside the task screen.
Please can anyone help me so that those sub tasks are also visible directly on the board itself.
Best,
Jack Brickey
indeed this is the case for the "default" business board that is created when you create a business project. You might find this related thread useful - How-to-see-Sub-Tasks-on-Business-Project-board  which captures an open suggestion - JRACLOUD-62667
Workaround - You could create a more full-featured Kanban board using the project or saved feature, save it to your profile (Location) and then add a shortcut to the board on your project page.
Ankit Chouhan August 15, 2020
Hi Jack,
Thank you for the clarification. It helps.
Best,
Ankit
Chase Wilson
February 25, 2021
Hi @Ankit Chouhan and @Jack Brickey , this has been resolved in recent updates to Classic Business projects. You can now see the number of total and completed subtasks on the board cards. Cheers!
