Subquery syntax when using scripted JQL funtion subtasksof(subquery) not working
Kelley Cooper
If I construct and run the following filter all is well:
project = ABC AND resolution not in (Withdrawn, Duplicate) AND Teamlet = "Team A"
My results do not include any items with Resolution = Withdrawn or Duplicate.
Now, if I try to use the above as the subquery in the subtasksOf JQL function the results are not 100% correct; I created this:
issueFunction in subtasksOf('project = ABC AND resolution not in (Withdrawn, Duplicate) AND Teamlet = "Team A"')
my results include some issues with Resolution = Withdrawn or Duplicate; what am I doing wrong?
Mohamed Riza
September 12, 2018
Hi @Kelley Cooper
Do you mean to say that the result shows subtasks have resolutions with Withdrawn and Duplicate? If so, then you may want to change this as follows:
issueFunction in subtasksOf('project = ABC AND resolution not in (Withdrawn, Duplicate) AND Teamlet = "Team A"') AND resolution not in (Withdrawn, Duplicate)
Kelley Cooper
Thank you, @Mohamed Riza!
atlassian, jira product discovery, product operations, product ops, linkedin live, atlassian events, cross-functional collaboration, product management, engineering collaboration, design collaboration, atlassian learning, agile teams, product strategy
Product Ops Unpacked: 4️⃣ tips every product pro needs to know ✍️
Join PM Evangelist, Axel Sooriah, & Product Ops. Consultant & Advisor, Jenny Wanger, as they unpack the role of product ops and discuss key takeaways in Atlassian’s ‘The Product Ops Mission’ guide. They’ll answer your questions live on May 6 at 9:00am PT.
Register here ⬇️
