Subtask summary column not showing entire parent issue summary, but its key
Peter Tilsen
September 3, 2015
Is there a way to make the summary more verbose, by showing the entire name of the parent issue? This output is a dashboard filter result gadget.
Rodrigo Rosa
September 3, 2015
Hello Peter,
If I understood correctly the situation you described, there is a feature request for it here.
Rodrigo Rosa
Peter Tilsen
September 3, 2015
@Rodrigo Sogari [Atlassian], yes indeed. This is my issue. thanks for linking.
