×Is there a way to show a list of issues that already cover the issue I want to create?
In daily work, one does not have all existing issues in mind and sometimes creates issues twice because he does not know that there is already an issue that deals with it.
Is this planned or already solved by a plugin?
Hi Ron,
nothing I would be aware of for the create screen. You could check marketplace but on a quick check I could not find any App that would be catering this need.
The somewhat nearest feature would be the "quick searching" - the search box on the right upper which allows searching in real time.
https://confluence.atlassian.com/jirasoftwareserver/quick-searching-939938728.html
Daniel
Thanks!
I also searched and found nothing in the marketplace.
The quick search is used a lot ;-) As you can move to the input via keystrokes and so on ;-)
