Suggested workaround doesn't seem to work
Douglas Lee April 14, 2016
This question is in reference to Atlassian Documentation: How to set default value for Summary Field in JIRA
This didn't work for me.  The javascript code was simply printed underneath the Summary field in the Create Issue form.
Peter T
April 14, 2016
Hi Douglas,
its tricky, if you are not on the cloud, you can use this:
https://marketplace.atlassian.com/plugins/com.gebsun.plugins.jira.defaultvalues/server/overview
Peter T
Thanks Peter for the suggestion.  But in my case, I'm using the Cloud version.  Do you know of a similar solution that works with Cloud?
Peter T
April 14, 2016
I am afraid no. The cloud has its perks but quite a lot of limitations too.
If you are interested in migration to on-prem, let me know.
OK.  Then I would suggest updating the KB article.  Currently it says it applies to JIRA On-Demand (aka cloud), which is incorrect.
Steven F Behnke
April 14, 2016
You're right, that is incorrect. We're just a community of users though, most of us cannot update the articles.
There's only a "is this helpful" button, so I marked it as "inaccurate." Hopefully that gets looked at! smile
Ah, thanks for pointing out that this a community forum.
