Sync issue from one project to the other project live
Shawn July 27, 2020
This automation function allows us to replicate tickets from board to board. i.e., I've got it setup that when a story is raised in the A board, it creates a duplicate in the B board, and then any updates to the original ticket's description updates the B ticket. In antother words, when a ticket is added, it will immediately be synced over to the other project. Project A and project B are in the same JIRA account.
How to create the syncing feature in JIRA cloud?
Julie d_Antin _Elements_
Hello  @Shawn
Our app Elements Copy & Sync would be able to do that for you. It allows you to copy fields, comments, and/or attachments to new issues, and keep them synchronized.
The Cloud version is not yet available on the Atlassian Marketplace, but you can sign up to be notified when the app is released: https://copy-sync-cloud.elements-apps.com/
Matthias Gaiser _K15t_
Hi @Shawn,
you described a way how you can automate the creationg and updateof your issues between your projects already.
What other syncing feature are you looking for?
Matthias.
