Synchronizing JIRA with 3rd Party System
Khurram Mir
February 5, 2013
I want to synchronizing my bug tracking system to JIRA. I use different rest api approaches to get bug information, but not get appropriate information.
http://example.com:8080/jira/rest/api/2/issue/{issueIdOrKey} [GET, DELETE, PUT] http://example.com:8080/jira/rest/api/2/search [GET, POST]
but both of these cant give me appropriate information.
and one more these can me protected properties of json, which is not able to parse.
[requestLength:protected] => 0 [acceptType:protected] => application/json [responseBody:protected] => {"expand":"renderedFields,names,schema,transitions,operations,editmeta,changelog", ....
Look at protected properties of json.
What i am looking for
1-Get latest Status of the bug. 2-Parse protected properties of JSON.
Gary
February 8, 2013
Hi Khurram,
To pull the status back of an issue, you would just need to add '/status':
http://example.com:8080/jira/rest/api/2/issue/status [GET]
For #2, can you show me the contents of the script you are using (minus the credentials)?
Gary
Khurram Mir
February 11, 2013
This give me all of the bugs in the system,i only want spacific bug whoes bug id is given.
one more thing JSON responce is protected ([responseBody:protected]) how i get ([responseBody]) with out protected condition.
