System error when converting issue into a sub-task.
sherwin ncna
When i make a sub-task for an issue it works just fine but when i convert an issue into a sub-task it shows a system error saying:
Cause:
net.java.ao.sql.ActiveObjectSqlException: java.sql.SQLException: There is already an object named 'AO_60DB71_RANK_ISSUE_LINK' in the database.
Stack Trace: [hide]
at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.migrate(EntityManagedActiveObjects.java:44)
at com.atlassian.activeobjects.internal.AbstractActiveObjectsFactory.create(AbstractActiveObjectsFactory.java:52)
Help please. Thanks.
sherwin ncna
We just updated all the plugins installed and now it's working smoothly again.
Jobin Kuruvilla [Adaptavist]
August 30, 2011
Do you have some plugins that uses Active Objects? A plugin used for issue ranking? Looks like it is not handling the scenario mentioned!
