System plugins failed to start: We haven't been able to start all the required system plugins
Vishnu Rajawat
July 24, 2022
Please help me to resolve below error when i'm installing JIRA on my MAC:
We couldn't start the following plugins:
  • jira webresources-plugin (jira webresources)
  • Atlassian Front-End Runtime Plugin (com atlassian frontend atlassian-frontend - runtime-plugin)
I'm using java version "18.0.1.1" 2022-04-22
Dheeraj Kumar Aggarwal
Hi @Vishnu Rajawat ,
I am getting the exact same issue on the MAC machine. What solution have you tried to resolve the above error?
Nic Brough -Adaptavist-
December 14, 2022
Hopefully, they followed the advice in the linked article, and that fixed it.
July 24, 2022
This could be caused by all sorts of things, but the usual one is simple load - Jira would like more memory (the default installation numbers are usually too low for anything more than a basic install with no Software or Service Management installed)
See https://confluence.atlassian.com/jirakb/troubleshoot-a-jira-server-startup-failed-error-394464512.html
