This part don't load at all and other components of our automation rules on our cloud instance load too long. Is there any limits that couse this issue or ways to make it work normal?
Hi @g_halilov ,
Welcome to the community!
Yes cloud instance do have service limits based on your plan. Check this link for more information.
Can you try using Permission helper and see if you have Assign issue permissions for this project ?
Go to Project Settings > Permissions > Permission Helper.
Aditya
Hi @g_halilov Welcome to the Atlassian Community!
Have you been granted the Browse users and groups Global Permission?
