Tempo does not work anymore
Bianca Woelke August 5, 2020
Hi folks,
my TEMPO shows not up any more. Yesterday it still workd and now blank page when loading.
I cleared cache / cookies, checked if any tracker are active... nothing helps.
Any ideas?
Thank you,
Bianca
Ólöf Kristjánsdóttir {Tempo}
Hi Bianca
You could try opening development tools -> console and see what error is there. If the problem persists, I recommend issuing a support ticket with our support team so they can investigate. You can submit a ticket here: https://tempo-io.atlassian.net/servicedesk/customer/portal/6
Hope the problem resolves quickly!
Best regards,
Ólöf (Tempo team)
Hi Ólöf,
thank you for your answer.
I opened now a ticket as a lot of my colleagues are also seeing this problem (working from office and home, so not at the same network).
Console states ton´s of errors like:
Failed to load resource: the server responded with a status of 409 ()
Error while parsing the 'sandbox' attribute: 'allow-storage-access-by-user-activation' is an invalid sandbox flag.
instrument.ts:129 Error: Minified React error #185; visit https://reactjs.org/docs/error-decoder.html?invariant=185 for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
Uncaught (in promise) Error: Minified React error #185; visit https://reactjs.org/docs/error-decoder.html?invariant=185 for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
purplebox.js:8 Uncaught Error: Attempting to use a disconnected port object
at C (purplebox.js:8)
at purplebox.js:8
index.js:341 Object
e @ index.js:341
index.js:507 {"msg":"captureError","name":"ChromeRuntimeError","message":"Could not establish connection. Receiving end does not exist."}
H @ index.js:507
tempo-app#!/planner?periodType=CURRENT_MONTH:1 Unchecked runtime.lastError: Could not establish connection. Receiving end does not exist.
Hi again Bianca
Tempo Planner is experiencing some loading issues that are probably the source of your problems. You can monitor our status page for updates on the matter: https://status.tempo.io/ Our team is working hard on a solution.
Let me know if the problem persists on your end.
Best,
Ólöf (Tempo team)
Thank you very much!
Seems like it´s working again :-)
Thank you for the help!
Best regards,
Bianca
Great to hear! Let us know if you need any further assistance!
Best,
Ólöf
