I'm wondering if anyone has any thoughts tools to use for test case management that also integrates well with JIRA. We have installed a trial of Zephyr for 5.0 which seems awesome, we just need to see if QA agrees. They purchased Enterprise Tester before really evaluating it, and frankly it seems difficult to use and like a nightmare from an administration perspective. Any experiences with these tools, or other ones you would reccommend?
Thanks!
KeriB
A similar discussion here
https://answers.atlassian.com/questions/38831/jira-for-test-management
Related links
http://confluence.atlassian.com/display/CONFEVAL/Using+JIRA+for+Test+Case+Management
Hi KeriB,
I have just started on discovery for a lowcost test mgt suite --looking seriously at JIRA for defects and eventual inegration into CI (Jenkins, Fitnesse, etc).
but right now i'm looking at the Test Case management options: ie, create, alocate, execute and report test cases / test sets.
i see you mention *Zephyr* --did you carry on with that? what is t=your verdict?\
any help much apprciated.
thanks James
zAgile's open source Wikidsmart delivers both Test Case Management and Requirements Management within Confluence, all integrated with JIRA. Also you can achieve Test Automation with Selenium also integrated with JIRA. Here's a recorded webinar: http://www.zagile.com/products/Wikdismart_QA.html
Hi KeriB,
I would like to suggest a tool that I have been developing TestLodge test case management
TestLodge is a relatively new hosted tool that is designed to be a lot simpler than traditional software by only providing the essentials to get the job done well. The system focuses on helping you create your test plans, input your requirements, create and manage your test suites and cases along with allowing you to easily perform multiple test runs and generate reports.
The Jira integration has the following functionality:
- Link a Jira project to a TestLodge project
- Whenever a test case fails, automatically create a ticket in jira.
- Easily link your Jira account with TestLodge.
If you have any questons, just get in touch with us.
Scott
Hey Scott,
I am intersted in TestLodge. Does this work for JIRA onDemand version? Is there any other info about TestLodge - JIRA intergration? (e.g. blog post, etc)
Miki
Hi Miki,
Yes TestLodge does work with the onDemand version (as well as the self install version).
We dont have any blog post yet for Jira, but we do intend on creating a short video of how this works in future. For now the only addiitonal infomation can be found on https://marketplace.atlassian.com/37275 and on our tour page at http://www.testlodge.com/tour
Once you have created an account, if you go to the account tab, his will provide you with all the information that you need to set things up. (we've tried to keep things as simple as possible, so all you need to provide is some authenticaiton details and tell the tool the url of your on demand account)
If you have any further questions, just get in touch with us at http://help.testlodge.com/
Scott
Hi Scott,
I checked the below link and it is saying TesrLodge Add on is not available for Cloud'
Regards.
Thanks for pointing that out. I have updated our description to mention that we also support Jira on demand and self hosted versions.
Scott
Hi Scott,
Thank you for quick action. I am trying to use this add on on the JIRA onDemand. But I could not find this plugin in Admin Add-Ons list.
It would be great if you provide the procedure to configure TestLodge and JIRA OnDemand?
Kiranmai
https://marketplace.atlassian.com/37275 says it is not available for Cloud (Jira OnDemand)!
Hi llya, The integration does work with both OnDemand and self hosted versions. We just can't get that part of the integration page to say this as we don't charge for it using Jira's billing system.
There is a requirements management plugin for JIRA - RMsis. This tool includes test case management as well.
https://plugins.atlassian.com/plugins/com.optimizory.rmsis.plugin.jira-rmsis
