Test case Management Tools and JIRA Studio
Deleted user November 22, 2011
Are there any Test case management tools that can be integrated with JIRA Studio? Something like - http://confluence.atlassian.com/display/CONFEVAL/Integrate+JIRA+With+A+Test+Case+Manager
3 votes
TimT
November 22, 2011
You can have a look at Zephyr.
Deleted user November 23, 2011
Thanks Tim. We'll look into Zephyr.
Scott Sherwood April 30, 2012
Not sure if you found what you were looking for, but you may also want to consider TestLodge - Test case management tool
The integration has the following features
  • Whenever a test case is marked as failed, TestLodge will automaticlly create a ticket in Jira. (Ticket creation can either be opt in or opt out.)
  • Choose which jira project to create the tickets in
  • View a report providing links to all tickets that have been created.
For a quick overview of how TestLodge works you can take a look at the overview video at http://www.testlodge.com/tour/overview_video
BryceD
August 13, 2012
Nikhil take a look at Enterprise Tester.
Enterprise Tester doesn't need any plug-in to integrate with JIRA studio.
www.enterprisetester.com
Happy testing!
Bryce
Dennis Gurock November 29, 2011
you might also want to look into TestRail test management, as it integrates well with JIRA Studio (as well as with the new Atlassian OnDemand or with self-hosted instances):
http://www.gurock.com/testrail/jira-test-management.i.html
