×Hi,
I'm looking for a simple way to secure that a function developed by a developer (managed with a JIRA issue), can be documentet as testet.
I have looked at different plugins, but most of those I've been looking at, requires a huge test management system.
What I need is, just the posibility to add information in a JIRA issue, stating that the issue has been testet OK/Not OK and then a simple test description.
Ideas:
- Having a text field where the test description can be added when the JIRA issue is created
- Having check boxes for OK / Not OK
Claus
Hi Claus, have you tried adding a custom field? It might help you do what you need. Here is an article I found: https://confluence.atlassian.com/adminjiraserver071/adding-a-custom-field-802592519.html
Hi Pavel.
Yes - I've added a costum field. And that helped med with gathering more precise information when a JIRA case is created. I've also added an ekstra plugin called "SmallTest for JIRA", that helps with getting our developers adding test information and test results.
So I think we are OK for now :-)
Claus
