Test plan and test execution
manikandan.dhanaraj May 27, 2020
2 Questions?
1. Is it possible to run the one test execution (Set of tests) multiple times in a test plan.
2. Is it possible to create 2 test plan with one test execution?
For example: If I run the Test execution 1 in Test plan 1
again same Test execution 1 in test plan 2?
or do I need to create 2 separate test executions for 2 test plans?
Benjamin
Hi @manikandan_dhanaraj - You can have all those flexibilities depending on the test management tool you use. Jira is not a test management tool but it can integrate with many test management tools out there.
FREE
