TestRail and Cypress Integration Guide
Joni Aiam
August 25, 2021
I am trying to setup TestRail as the test repo and Cypress as the automation tool. Anyone has the step by step guide to integrate the 2 ? My goal is to run successfully one test script and post back results to TestRail. Site
THanks,
Noopur Varshney _AIO Tests_
Hi @Joni Aiam
You can try AIO Tests. It has a native integration with Cypress.
You can add testcase keys to your test descriptions and the reporter can publish results to the tests after run.
Find more details here - https://www.npmjs.com/package/cypress-aiotests-reporter
If you want a walkthrough, please reach out to us via our support portal or setup a time at your convenience.
Noopur
AIO Tests Team
