The seach bar on the top right is not adding the base url to the link.
If I type in a string to the search bar, it comes back eg:
issues/?jql=text%20~%20%22search%22
whereas a specific ticket search works:
http://ianandsarah.tk/browse/TT-184
Everything else seems to be working fine.
Any ideas?
As suspected, problem caused by my own tinkering: I changed the Context path to "/" from "" while setting up the proxypass.
I fixed by intalling the latest version and then diffing the xml files.
Thanks everyone for pointing me in the right direction!
Ian
Ian,
Did you change the server.xml file?
Maybe you did something wrong there.
Also did you maybe do something in the hosts file?
Best regards,
Peter
I did change the server.xml file, perhaps something went wrong there, yes:
<Service name="Catalina">
<!-- Standard HTTP Connector -->
<!-- Apache Proxy Connector -->
<Connector port="9080"
maxThreads="150"
minSpareThreads="25"
connectionTimeout="20000"
enableLookups="false"
maxHttpHeaderSize="8192"
protocol="HTTP/1.1"
useBodyEncodingForURI="true"
redirectPort="8443"
acceptCount="100"
disableUploadTimeout="true"/>
proxyName="ianandsarah.tk"
proxyPort="80"/>-->
I removed the proxy,
/etc/hosts is unchanged
Is it perhaps to do with the redirectPort (it's not open to telnet). I can't seem to find anything about it on the atlassian site.
Ian
Hi Eduardo,
Thanks for getting back!
I've since dropped the web proxying to simplify things.
My system administration is also affected (the form on http://ianandsarah.tk:9080/secure/admin/ViewApplicationProperties.jspapoints to / so I hack the web form to get access) but I can also get the base url from the logs
The base URL is:
___ Core Application Properties ____________
Version : 6.2.6
Build # : 6264
Build Date : Tue May 20 00:00:00 BST 2014
Installation Type : Standalone
Server ID : BT6T-S44C-ZXMH-ZEHT
Base URL : http://ianandsarah.tk:9080<br< a="">> Default Language : English (United States)
External User Management : OFF
This shows up in my logs when I do a search:
109.152.198.119 490x49x1 ian.miell@gmail.com[10/Jun/2014:08:10:08 +0100] "GET /secure/admin/ViewApplicationProperties.jspa HTTP/1.1" 200 5724 110 "http://ianandsarah.tk:9080/secure/Dashboard.jspa" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:29.0) Gecko/20100101 Firefox/29.0" "1aua5dj"
109.152.198.119 490x50x1 ian.miell@gmail.com[10/Jun/2014:08:10:09 +0100] "GET /rest/helptips/1.0/tips HTTP/1.1" 200 142 6 "http://ianandsarah.tk:9080/secure/admin/ViewApplicationProperties.jspa" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:29.0) Gecko/20100101 Firefox/29.0" "1aua5dj"
109.152.198.119 490x51x1 ian.miell@gmail.com[10/Jun/2014:08:10:09 +0100] "GET /rest/nav-links-analytics-data/1.0/?_=1402384208952 HTTP/1.1" 200 62 5 "http://ianandsarah.tk:9080/secure/admin/ViewApplicationProperties.jspa" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:29.0) Gecko/20100101 Firefox/29.0" "1aua5dj"
109.152.198.119 490x53x2 ian.miell@gmail.com[10/Jun/2014:08:10:09 +0100] "GET /rest/jag-marketing/1.0/config?_=1402384208962 HTTP/1.1" 200 104 2 "http://ianandsarah.tk:9080/secure/admin/ViewApplicationProperties.jspa" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:29.0) Gecko/20100101 Firefox/29.0" "1aua5dj"
109.152.198.119 490x52x1 ian.miell@gmail.com[10/Jun/2014:08:10:09 +0100] "GET /rest/stp/1.0/license/status?_=1402384208958 HTTP/1.1" 204 - 3 "http://ianandsarah.tk:9080/secure/admin/ViewApplicationProperties.jspa" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:29.0) Gecko/20100101 Firefox/29.0" "1aua5dj"
109.152.198.119 490x54x1 ian.miell@gmail.com[10/Jun/2014:08:10:12 +0100] "POST /secure/QuickSearch.jspa HTTP/1.1" 302 - 10 "http://ianandsarah.tk:9080/secure/admin/ViewApplicationProperties.jspa" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:29.0) Gecko/20100101 Firefox/29.0" "1aua5dj"
From a tail of all "*10" logs here:
root@rothko:/opt/atlassian/jira/logs# ls -lrt | tail
-rw-rw-r-- 1 jira jira 302 Jun 8 20:16 localhost.2014-06-08.log
-rw-rw-r-- 1 jira jira 2102 Jun 8 20:33 catalina.2014-06-08.log
-rw-rw-r-- 1 jira jira 938160 Jun 8 21:54 access_log.2014-06-08
-rw-rw-r-- 1 jira jira 687879 Jun 9 20:39 access_log.2014-06-09
-rw-rw-r-- 1 jira jira 0 Jun 10 07:22 manager.2014-06-10.log
-rw-rw-r-- 1 jira jira 0 Jun 10 07:22 host-manager.2014-06-10.log
-rw-rw-r-- 1 jira jira 1964 Jun 10 08:04 localhost.2014-06-10.log
-rw-rw-r-- 1 jira jira 17354 Jun 10 08:04 catalina.2014-06-10.log
-rw-rw-r-- 1 jira jira 4809434 Jun 10 08:05 catalina.out
-rw-rw-r-- 1 jira jira 622929 Jun 10 08:10 access_log.2014-06-10
Ian
Hey Ian,
Did you check the Base URL on your Jira Administrator panel?
Also, could you paste here what entries appear on your <jira-home>/log/atlassian-jira.log when you perform the search?
Best regards,
Eduardo Mallmann
Atlassian Support
