The Resolution of the issue will be set to Done post function
mnpiad
I am using JIRA cloud
In the default workflow when there is a transition from (in progress–> to done ) i see a post function with name " The Resolution of the issue will be set to Done"
When i created custom workflow and in last transition from (testing—> completed)  i want to use the same post function but i do not see that post function how do i set it up.?
Reason there is a resolution field by default in issue and it always shows "unresolved"  can i remove thie resolution filed ?
-Thanks
Shawn C
February 2, 2017
Hey Mehul,
Look for the Update Issue Field post function; this would allow you to choose the Resolution field and set the resolution value as needed.  https://confluence.atlassian.com/jirakb/jira-issues-need-a-resolution-826873869.html
-shawn
mnpiad
Thanks much !!!
