The best test management for Jira
Deleted user August 15, 2023
Hi community,
I am new here, we are looking for a test management tool for our new project. Could you introduce a good and flexible one?
Please don't propose xRay or Zephyr, I already tried them but they are too old and too expensive.
Steve
Tam _DevSamurai_
Hi Steve,
You should take a look at this new app called AgileTest
It is very flexible, supports all testing strategies
- Test Script to quickly write tests, checklists, execute test and generate reports
- Ad-hoc test with test session for more rapid release cycles & continuous delivery
- If you want to do detailed traditional test management it also supports well with the full-featured general test management strategy with Test Case, Test PreCondition, Test Suite, Test Steps, Test Plan, Test Run and comprehensive reports.
Please take a look at this video for more info
You can find more info and resources from its website Test Management for Jira
P/S: I am working for DevSamurai the maker of AgileTest.
Tam
Hey Tam,
Thanks for the answer, I will take a look at your tool.
Like # people like this
6 votes
Brijesh Patel
Hi Steven,
I would like to suggest QTM4J (QMetry Test Management for Jira) which is providing end to end to test management capabilities and emerge as the BEST VALUE BASED TEST MANAGEMENT APP within Atlassian ecosystem.
Brijesh Patel.
Deleted user August 16, 2023
Thanks!
3 votes
Ewa Grabowska-Ptak_SolDevelo_
Hi @[deleted]   ,
Nice to meet you! I would like to recommend to you our QAlity Plus - Test Management for Jira
While creating QAlity Plus, we wanted to provide users with an easy and swift solution to perform manual tests. Some of the features that might interest you are:
- History of past executions on the execution page - did it happen before or is it a new bug? With execution history, you can save time on wondering and simply check, without switching context, all the bugs and failed steps that were previously reported.
- Report or link bugs directly from the Test Steps - when you create a bug, the reproduction steps are automatically copied from the Test Case. So, you can save time and not repeat your work.
- Traceability report - which allows you to compare which tests are more successful in finding defects than the others and learn what should be improved.
You can start a 30-day free trial here, or check out the app in the interactive demo here. Should you have any questions, I will be happy to assist you or schedule a demo call.
thanks!
ritvick_udasi October 20, 2023
I understand your need for a cost-effective test management solution for your client, especially if Xray & Zephyr doesn't fit within their budget. One excellent alternative that I would recommend considering is "QMetry Test Management for Jira."
QMetry Test Management for Jira offers a robust set of features for managing tests and test cases within the Jira environment, making it a seamless choice for teams that are already using Jira for project management and issue tracking. Here are some reasons why you should consider QMetry Test Management for Jira:
1. Integration with Jira: QMetry seamlessly integrates with Jira, allowing you to create, manage, and track test cases directly within your existing Jira projects. This integration ensures a smooth workflow for your team.
2. Affordable Pricing: QMetry offers competitive pricing, which can be more budget-friendly compared to some other test management tools, including Xray. This makes it an excellent choice for teams looking for cost-effective solutions.
3. Comprehensive Test Management Features: QMetry provides a wide range of test management features, including test planning, test execution, and comprehensive reporting. It supports both manual and automated testing, catering to different testing requirements.
4. Ease of Use: QMetry's user-friendly interface makes it easy for your team to create and organize test cases, execute tests, and generate detailed test reports without a steep learning curve.
5. Scalability: QMetry is suitable for both small teams and large enterprises, offering the scalability to grow with your client's needs.
6. Support and Community: QMetry has an active community and provides good customer support, ensuring that you have the resources you need to get the most out of the tool.
In conclusion, QMetry Test Management for Jira is a reliable and cost-effective test management solution that can seamlessly integrate with your client's Jira environment. It offers the essential features needed for effective test management and comes at a lower monthly price point compared to some other options. I recommend giving it a try and exploring whether it meets your client's requirements.
Best regards,
Ritvick Udasi
Noopur Varshney _AIO Tests_
Hi @[deleted]
Do checkout AIO Tests also. It is a modestly priced app and it offers all the key features of a test management tool. It goes beyond in reporting capabilities too. Please feel free to go through our documentation or setup a demo with an expert.
It's a very intuitive app with zero setup time and supports the entire testing lifecycle.
Here is a list of the key features and we keep adding more:
  • easy creation and import of test cases
  • linking to Requirements (Jira stories)
  • organizing in Folders and Sets
  • efficient execution with analytical view of multiple test executions
  • easy recording of run defects and artifacts
  • inbuilt traceability and execution reports
  • a number of gadgets to view all information on Jira Dashboards
  • Integration with numerous Automation Frameworks (Cucumber, JUnit, NUnit, TestNG, Postman, etc.)
  • Cypress and Katalon Studio integrations
  • Jenkins plugin
Please feel free to reach out to us via help@aiotests.com.
Noopur (AIO Tests Team)
Gal Fatal
Hi @[deleted]
I can recommend on a new app in the marketplace.
Tricentis Test Management for Jira
This app brings the latest technology with embedded AI engine.
Worth trying - free for up to 10 users, and much cheaper than the big and old testing apps players.
Good luck
Gal
Tam _DevSamurai_
Hi Steve,
You should take a look at AgileTest Test Management for Jira .
It supports all testing styles and strategies.
Tam
Fadi Hawli
Also you have Vansah , QMetry Zephyr Squad and Xray
