we have the same problem descibed here https://jira.atlassian.com/browse/JRA-24383
Can you show us a short workaround for this bug?
Whe will it get fixed?
According to the raised bug, the workaround are:
<tt>Administration > Global Settings > Time Tracking</tt>
Deactivate time tracking, and setTime Format to pretty. Then, activate time tracking.
Have you try the suggested workaround?
Yes this works. Thanks
