Timeline View - Issues not appearing
John Chadwick
July 26, 2023
I have a Jira Software project that is used to track a yearly audit. All of the controls were created as individual issues in 2021, then worked through their workflow statuses from "On Deck" to "Passed".
In 2022, all of the resolved issues were moved back to "On Deck" using the bulk editor, then worked through their workflow statuses again.
Now in 2023, I find myself responsible for shuffling these around and I've run into a snag.
In the Timeline View Gantt chart, I can't see the bars for any issues. I've tried updating the Start Date and Due Date fields in a few issues, but they don't populate. I've also confirmed that these issues are using the default Start/Due Date fields to rule out field-creep.
Scrolling back to September of 2022 where most of the issues still have their Start/Due Dates set, I still don't see the issues represented in the Gantt.
I'm unsure if this was an issue experienced in 2022 as well, but would like to figure out how to get the timeline view fixed for this year.
John Chadwick
July 26, 2023
Digging into this a bit more, I think this may be related to the Resolution field having a status. Changing to other statuses does not correct the problem. I believe there's a way to clear resolution; just need to find it.
Update: Set up a post-function according to these instructions (https://confluence.atlassian.com/jirakb/clear-the-resolution-field-when-an-issue-is-reopened-in-jira-server-648381467.html). Resolution was cleared on a test issue, but it' still not showing up in Timeline view.
Ishwara Bhat
September 16, 2024
I got timeline view. At epic level I could see Gantt chart bars. But not at issue level. Later I configured Target Start, Target, End, Actual Start and Actual End fields for issues.
Also had re-created boards.
Then in timeline I was able to see the graphs and was able to edit also.
Like 김혜진 likes this
