×Hi,
I'm using Drools integrated to Jira, where Jira is my backend with a database and drools manage some rules. I have a plugin to integrate this applications. When I register a issue in Jira via REST, the Jira give me a timeout error and Drools give me a broken pipe error. Someone had the same issue?
Here is my stacktrace on Jira:
2017-10-18 14:23:57,560 ajp-nio-8009-exec-5 ERROR jmarques 863x51003x1 1lhgtvq /rest/api/2/issue [c.a.j.bc.issue.DefaultIssueService] Error creating issue: com.atlassian.jira.exception.CreateException: Drools Integrator post-function error!: root cause: [Drools Integrator] Erro: SocketTimeoutException: Read timed out detalhes: org.kie.remote.common.rest.KieRemoteHttpRequestException: Error occurred when trying to retrieve response code at org.kie.remote.common.rest.KieRemoteHttpRequest.responseCode(KieRemoteHttpRequest.java:1307) at org.kie.remote.common.rest.KieRemoteHttpRequest.post(KieRemoteHttpRequest.java:719) at org.kie.server.client.impl.AbstractKieServicesClientImpl.makeHttpPostRequestAndCreateServiceResponse(AbstractKieServicesClientImpl.java:179) at org.kie.server.client.impl.AbstractKieServicesClientImpl.makeHttpPostRequestAndCreateServiceResponse(AbstractKieServicesClientImpl.java:169) at org.kie.server.client.impl.RuleServicesClientImpl.executeCommands(RuleServicesClientImpl.java:52) at br.org.ccee.jira.plugin.DroolsIntegrationCommand.callExternalDrools(DroolsIntegrationCommand.java:81) at br.org.ccee.jira.plugin.DroolsIntegrationCommand.execute(DroolsIntegrationCommand.java:57) at br.org.ccee.jira.workflow.DroolsIntegratorPostFunction.execute(DroolsIntegratorPostFunction.java:21) at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1050) at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1446) at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:615) at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:741) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:580) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:494) at com.atlassian.jira.bc.issue.DefaultIssueService.create(DefaultIssueService.java:230) at com.atlassian.jira.bc.issue.DefaultIssueService.create(DefaultIssueService.java:199) ... 2 filtered at java.lang.reflect.Method.invoke(Method.java:497) at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26) at com.sun.proxy.$Proxy75.create(Unknown Source) ... 2 filtered at java.lang.reflect.Method.invoke(Method.java:497) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317) at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56) at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133) at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70) at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133) at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207) at com.sun.proxy.$Proxy2248.create(Unknown Source) at com.atlassian.jira.rest.v2.issue.CreateIssueResource.createIssue(CreateIssueResource.java:166) at com.atlassian.jira.rest.v2.issue.CreateIssueResource.createIssue(CreateIssueResource.java:57) at com.atlassian.jira.rest.v2.issue.IssueResource.createIssue(IssueResource.java:596) ... 2 filtered at java.lang.reflect.Method.invoke(Method.java:497) ... 5 filtered at com.atlassian.jira.rest.exception.ExceptionInterceptor.intercept(ExceptionInterceptor.java:55) ... 1 filtered at com.atlassian.jira.rest.v2.issue.scope.RequestScopeInterceptor.intercept(RequestScopeInterceptor.java:39) ... 14 filtered at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:154) ... 1 filtered at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:68) ... 91 filtered at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:70) ... 15 filtered at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:37) ... 22 filtered at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:169) at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter$$Lambda$475/112474607.call(Unknown Source) at com.atlassian.servicedesk.internal.util.scala.ScalaJavaInterOp$1.apply(ScalaJavaInterOp.java:25) at com.atlassian.servicedesk.internal.utils.context.CustomerContextUtil$.outOfCustomerContext(CustomerContextUtil.scala:48) at com.atlassian.servicedesk.internal.utils.context.CustomerContextUtil.outOfCustomerContext(CustomerContextUtil.scala) at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.outOfCustomerContext(CustomerContextServiceImpl.java:24) at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:164) at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:120) at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:112) ... 54 filtered at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745) Caused by: java.net.SocketTimeoutException: Read timed out at java.net.SocketInputStream.socketRead0(Native Method) at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) at java.net.SocketInputStream.read(SocketInputStream.java:170) at java.net.SocketInputStream.read(SocketInputStream.java:141) at java.io.BufferedInputStream.fill(BufferedInputStream.java:246) at java.io.BufferedInputStream.read(BufferedInputStream.java:345) at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:704) at sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:647) at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1535) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1440) at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480) at org.kie.remote.common.rest.KieRemoteHttpRequest.responseCode(KieRemoteHttpRequest.java:1305) ... 268 more
And here is my stacktrace on Drools:
Oct 16, 2017 7:08:58 PM org.jboss.resteasy.core.SynchronousDispatcher handleFailure
ERROR: RESTEASY000100: Failed executing POST /server/containers/instances/jira-requisicao
org.jboss.resteasy.spi.WriterException: org.apache.catalina.connector.ClientAbortException: java.net.SocketException: Broken pipe (Write failed)
at org.jboss.resteasy.core.ServerResponse.writeTo(ServerResponse.java:262)
at org.jboss.resteasy.core.SynchronousDispatcher.writeJaxrsResponse(SynchronousDispatcher.java:615)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:527)
at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:125)
at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:208)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:55)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:50)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.kie.server.services.impl.security.web.CaptureHttpRequestFilter.doFilter(CaptureHttpRequestFilter.java:42)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:614)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.kie.integration.tomcat.JACCValve.invoke(JACCValve.java:101)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:423)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1079)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:318)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.apache.catalina.connector.ClientAbortException: java.net.SocketException: Broken pipe (Write failed)
at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:407)
at org.apache.tomcat.util.buf.ByteChunk.append(ByteChunk.java:371)
at org.apache.catalina.connector.OutputBuffer.writeBytes(OutputBuffer.java:432)
at org.apache.catalina.connector.OutputBuffer.write(OutputBuffer.java:420)
at org.apache.catalina.connector.CoyoteOutputStream.write(CoyoteOutputStream.java:91)
at org.apache.catalina.connector.CoyoteOutputStream.write(CoyoteOutputStream.java:84)
at org.jboss.resteasy.plugins.server.servlet.HttpServletResponseWrapper$DeferredOutputStream.write(HttpServletResponseWrapper.java:40)
at org.jboss.resteasy.util.CommitHeaderOutputStream.write(CommitHeaderOutputStream.java:64)
at org.jboss.resteasy.plugins.providers.StringTextStar.writeTo(StringTextStar.java:60)
at org.jboss.resteasy.plugins.providers.StringTextStar.writeTo(StringTextStar.java:20)
at org.jboss.resteasy.core.interception.MessageBodyWriterContextImpl.proceed(MessageBodyWriterContextImpl.java:117)
at org.jboss.resteasy.plugins.providers.jackson.JacksonJsonpInterceptor.write(JacksonJsonpInterceptor.java:112)
at org.jboss.resteasy.core.interception.MessageBodyWriterContextImpl.proceed(MessageBodyWriterContextImpl.java:123)
at org.jboss.resteasy.plugins.interceptors.encoding.GZIPEncodingInterceptor.write(GZIPEncodingInterceptor.java:104)
at org.jboss.resteasy.core.ServerResponse.writeTo(ServerResponse.java:250)
... 31 more
Caused by: java.net.SocketException: Broken pipe (Write failed)
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
at java.net.SocketOutputStream.write(SocketOutputStream.java:155)
at org.apache.coyote.http11.InternalOutputBuffer.realWriteBytes(InternalOutputBuffer.java:215)
at org.apache.tomcat.util.buf.ByteChunk.flushBuffer(ByteChunk.java:480)
at org.apache.tomcat.util.buf.ByteChunk.append(ByteChunk.java:366)
at org.apache.coyote.http11.InternalOutputBuffer$OutputStreamOutputBuffer.doWrite(InternalOutputBuffer.java:240)
at org.apache.coyote.http11.filters.ChunkedOutputFilter.doWrite(ChunkedOutputFilter.java:119)
at org.apache.coyote.http11.AbstractOutputBuffer.doWrite(AbstractOutputBuffer.java:192)
at org.apache.coyote.Response.doWrite(Response.java:499)
at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:402)
... 46 more
Here the JSON:
{ "fields": { "project": { "key": "CSE" }, "issuetype": { "name": "Requisição" }, "summary": "teste request 01", "description": "teste request 01", "customfield_10305": { "self": "http://homcse.energia.org.br/rest/api/2/customFieldOption/16158", "value": "Artifactory", "id": "16158", "children": [ { "self": "http://homcse.energia.org.br/rest/api/2/customFieldOption/16163", "value": "Artifactory", "id": "16163" } ], "child": { "self": "http://homcse.energia.org.br/rest/api/2/customFieldOption/16163", "value": "Artifactory", "id": "16163" } }, "customfield_11111": null, "customfield_10222": { "self": "http://homcse.energia.org.br/rest/api/2/customFieldOption/10607", "value": "Gestão de acessos", "id": "10607" }, "customfield_10223": { "self": "http://homcse.energia.org.br/rest/api/2/customFieldOption/10968", "value": "Esqueci ou tive a senha bloqueada", "id": "10968" } }}
a
@José Eduardo Trindade E Marques Welcome to the Atlassian community
Are you using a proxy or firewall? Are other integrations working?
