Timesheet Report will not load
Erwin Smith
Halfway through this morning's reporting the timesheet report failed to load and what I do everyday became unavailable.
I need to review time logs for payroll ending tomorrow
Andriy Zhdanov
January 31, 2017
Hi all,
I'm sorry for troubles caused by attempts to implement progress bar for the process of loading time tracking data. However, I've reverted recent changes, and believe issues should have disappeared. Please let me know if not.
Thank you.
Ignacio Pulgar
January 31, 2017
The best place for raising issues in Time Reports is the developers issue tracker:
https://bitbucket.org/azhdanov/jiratimesheet/issues?status=new&status=open
Or, alternatively, mention Andriy Zhdanov in your questions.
@Andriy Zhdanov, may you have a look at this issue?
Erwin Smith
Thanks for your reply, seems only users are doing the talking and not any support staff.  Anyway, it is the opposite for me.  I've been struggling all day, but when I check Sum Subtasks the report loads.  Hmm!?
Aylin Kohls
January 31, 2017
I have same problem. Time reports add-on is not showing result when the Sum subtasks check is checked. But if I uncheck the “Sum subtask” I get the report. Yesterday it worked just fine with the check selected.
