×There are a lot of schema and workflows created in JIRA over time, may I know is there a mechanism to compare (aka generate) the difference between schemas and workflows? How could it be achieved in JIRA v6 / JIRA v7?
Hi!
As far as know there's no such 'out-of-the-box' option.
You should do it manually just comparing it in your system or exporting as XML and compare files.
