We have just started using Jira Product Discovery to capture, vet and prioritize ideas for the next release / iteration.
If there are bugs or enhancements identified in the current release/iteration, should all work go into product discovery for prioritization or should these small items go directly into the backlog for the next release?
Where I think this could become an issue is in capacity planning. If work is in multiple places, don't want teams to be over-capacity.
How have others handled this?
just adding to @Kit Friend's answer: Issue linking is indeed a great way to keep issues from JPD and JSW projects connected to each other - however you are correct that it can be challenging to keep an overview across all your relevant tickets. Jira doesn't have a great view for this IMHO, but if you're open to solutions from the Atlassian Marketplace, you'll find options there.
E.g., this is how a cross-JPD-JSW overview could look in the app that my team and I are working on, JXL for Jira:
For context, JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting.
Since issue hierarchies can be based on issue links and/or Jira's built-in parent/child relationships (like epic/story, or story/sub-task), you can easily model a system where ideas sit at the top, and implementation work for these ideas is nested below.
Best,
Hannes
Hey Terry,
JPD is really designed for the initial funnel and high level roadmap view - for linked work and bugs etc you're better off planning them in Jira Software using the linked Delivery ticket functionality - the source of truth for capacity planning etc should be there.
On some clients we've triggered the automated creation of linked delivery tickets once JPD items reach a certain stage which reflects them being ready for capacity to be allocated etc.
