Is there a way to have a post-function to automatically transition another issue of a different type that belongs to the same Epic?
We have JIRA Misc Workflow Extensions installed. There are post-function options there to transition linked issues or parent issues, but since two issues belonging to the same Epic aren't linked between themselves this doesn't really work.
Maybe my question is clearer with an example:
Always within an Epic we have several issues of different types, but usually only one of each type. So for example, we would have issue types:
Type1
Type2
Type3
and each Epic has one ticket of each type.
What I want to achieve is that when an issue of, say, Type1 goes through a specific transition that it would then automatically trigger a transition of the issue of Type2 within the same Epic.
For example, we have:
EpicA
Issue1 == Type1
Issue2 == Type2
Both Issue1 and Issue2 are under EpicA.
Someone is working on Issue1 and transitions it to status "Done". When that happens, Issue2 gets automatically transitioned to status "In Progress".
Hi Eugenio, there is a simple way to do it with JIRA Workflow Toolbox plugin, sharing the same workflow among all issue types.
Now, I explain in detail the configuration to implement your example.
EXAMPLE:
EpicA
Issue1 == Type1
Issue2 == Type2
SOLUTION:
We implement it using 2 post-functions:
1) Insert "Copy a parsed text to a field" post-function in transition to status Done with the following configuration:
Text to be parsed is:
toString(filterByIssueType(linkedIssues("is Epic of", linkedIssues("has Epic")), "Type2"))
2) Insert "Write field on issues returned by JQL query" post-function in transition to status Done with the following configuration:
Conditional execution is:
%{00014} = "Type1"
Note that %{00014} is field code for Issue Type.
Once configured, transition to status Done will look like this:
Please, let me know if you have any doubt about this solution.
Fidel
That's tricky, since there's no direct link between issues 1 and 2. If there was any type of Issue Link, that would be easy with the JIRA Misc. Workflow extension.
The only thing I can think of without code would be a 2-step process:
I think that would work fine. Be aware that you risk seeing stack traces related to this in your logs, since the post functions will try to transition all issues under the Epic, but will fail because it doesn't find the specific workflow transition for them. This will likely generate errors.
Thanks. This seems like it could work, but if I could have the Epic only transition children of a certain type, otherwise it might just transition all issues in the Epic. We don't have separate workflows for each issue type and don't currently plan on having that, since our workflow is quite complex and maintaining clone copies doesn't make much sense.
If you can't make a special workflow, you need a special type of link either between issues 1 and 2, or between the Epic and issue 2. Like, the post-function from issue one calls a transition in the Epic, and the post-function from the Epic calls a transition through a "type2 link" that links to issue 2.
