I've successfully integrated JJupin to be invoked as a post function on a transition, but I'd also like to intercept a comment add for notification. The comment button is not a transition, so I'm not sure how I set the hook to be able to create the notification.
Suggestions?
I think I figured it out. I'll try configuring the SIL Listener from the Kepler Admin page. Looks like what I was looking for.
Hi Tim,
can you share your solution on this?
You need to use the SIL Listener function which you can configure from the Jira Admin -> Kepler General Parameters dialog. There is a listener available for all the standard events just like the Jira notification implementation. You can set up a listener for 'issues commented' and have a SIL script executed just like out of the transitions.
