Trigger Automation When JIRA Issues is mentioned in Confluence
Guy Langlois
March 10, 2021
Hi Team,
I would like to know if there is an automation trigger when an issue is mentioned in Confluence?
The idea is that when the issue is mentioned, it would automatically be moved out of Backlog to In Progress.
Thanks.
3 votes
hilarydub
March 11, 2021
@Guy Langlois great question. PM on Confluence Automation here. Cross-product rules like the one you've outlined above are at the very top of our list to add to Automation for Confluence & Jira. We're already working on plans to support the rule you outlined (and other cross-product rules like it) into the Atlassian automation platform, but we're still around 6 months out from having this live in product. We'll be sure to keep you posted when we ship cross-product rules for Automation!
Paz Grimberg February 23, 2022
Hi Guy,
I want to introduce you our Jcreate and C4J apps, that will take the integration between Jira and Confluence to the next level for you!
C4J and Jcreate together helps you to make sure your requirements content seen and controlled in Jira, increasing the connection between your developers to the requirements.
The C4J app allows you to see the content of the requirement written in Confluence when viewing the linked JIRA issue.
The Jcreate app allows you to create the issues in JIRA from the content in Confluence while displaying a full screen of JIRA with all kinds of fields and mandatory fields.
Best regards,
Paz Grimberg
Methoda Team
Guy Langlois
March 10, 2021
Thank you @Mikael Sandberg and @Brant Schroeder. I will look into both.
Have a great day. Cheers,
Mikael Sandberg
I believe the new automation for Confluence would allow you do do that, it was mentioned during the Tips for using Team Calendar and & Confluence Premium webinar.
Brant Schroeder
@Guy Langlois - Welcome to Community
There is nothing in the Jira Automation suite that would provide this as an option.  The automation triggers listen for events in Jira and not Confluence.  Maybe a third party app like ScriptRunner might work but I am not even sure about that.
FREE
