Triggering Slack notifications when issue moves projects
Hillary Petroski
August 4, 2016
I'm looking to receive a notification in Slack when a JIRA issue moves from one project to another. Is there an easy way to do this? Do the projects need to have the same workflow scheme?
Vladimir Horev [RaleyApps]
Hi Hillary,
You can achieve it with our add on Jirassimo
https://marketplace.atlassian.com/plugins/net.vacom.jirassimo/cloud/overview
With the following template (event issue_updated)
#foreach ($issue in $issues)
  #foreach ($item in $issue.lastchange.items)
    #if ($item.field == "project" and $item.fromString == "Source Project Name" and $item.toString ==    "TARGET_PROJECT_KEY")
        $issue.key was changed from $item.fromString to $item.toString
    #end
  #end
#end
Vladimir
Monica Farrell
January 18, 2017
Vladimir, is there a way to set up this template so that you don't have to specify the source project? We use multiple projects and I only want to monitor tickets that have been moved into my project.
@Monica Farrell Yes, absolutely. Just try the following:
  #if ($item.field == "project" and $item.fromString != "Source Project Name" and $item.toString ==    "TARGET_PROJECT_KEY")
