×When this user (a Project Admin) clicks to edit the workflow they can then edit the workflow.
When the same user tries to add a transition the links aren't available like they are as JIRA Admins.
Any ideas why this may be? Screenshots attached
Only JIRA admins have full control over project workflow.
Since JIRA 7.3, project admins can also edit the project's workflow but with some restrictions listed below -
Thanks Tarun.
Editing the workflow works fine.
It's just that the project admin can't create a transition though - the option isn't available for them as show on the screenshot (we're on Version 7.4).
The workflow also isn't used on any other projects
