Trouble commiting DueDate after setting it with groovy/script runner
Michael Edwards
February 3, 2020
Currently, we have routine issues where the status resets each week. This escalation service is working as intended. However, we are trying to incorporate the following script to adjust the system field 'DueDate' to be set for 7 days from the date when the escalation fires. The following code updates the date and returns the correct value but it doesn't appear to be committing the date of the provided ISSUEKEY.
Here is our code:
import java.sql.Timestamp
IssueManager im=ComponentAccessor.getIssueManager()
MutableIssue issue = im.getIssueObject('ISSUEKEY')
issue.setDueDate(new Timestamp((new Date() + 7).time))
issue.getDueDate()
Leo
@Michael Edwards,
May I know where you are running this script?
 1. Post-Function?
  >>> If so check the order of post-function, it should be top of re-index post-function
2. Script Listener?
>>> if so you'll have to include "EventDispatchOption" method
def appUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
//place duedate update code here
issueManager.updateIssue(appUser, issue, EventDispatchOption.ISSUE_UPDATED, false)
Hope this helps
BR,
Leo
Michael Edwards
February 4, 2020
Trying to run it in the build-in script as part of an escalation service.
Fernando Bordallo
February 3, 2020
