Trouble connecting GitHub to Jira
Rohuma India
October 12, 2013
Follwed the directions at https://confluence.atlassian.com/display/AOD/Linking+a+Bitbucket+or+GitHub+repository+with+JIRA+OnDemand
But cant get this to work ..
On GitHub, I created a new application called it 'JIRA DVCS', set both homepage and callback url to https://snaplion.atlassian.net/
Then on Jira, I entered the oAuth Key and Secret, and set my username to 'NikhilSama'
I get the error 404, then
NikhilSama
Invalid credentials, please reset OAuth settings
Pls advise
AgentSmith
October 12, 2013
This is a bug and it can be watched here:
https://jira.atlassian.com/browse/DCON-324
Barring any issues, the fix should be deployed in Monday's release. That being said, in the meantime you can raise a support case at support.atlassian.com and we can manually apply the fix for your instance.
Hope this helps!
