Trying to add Security Level to Issue Layout
Michelle November 3, 2023
When I try to drag over the 'Security Level' field in my project issue layout screen so I can see and set it when I create/edit/view an issue, it drags across as expected but when I save the changes it resets the layout and removes the Security Level' field.
I think I have all security permissions/settings configured correctly so not sure why it keeps resetting it
Screenshot 2023-11-03 170542.jpgScreenshot 2023-11-03 170719.pngScreenshot 2023-11-03 170811.jpgScreenshot 2023-11-03 170858.jpg
Marko Blagus
November 4, 2023
Hello @Michelle,
Do you think or do you know you have issue Issue security scheme for your project and that you have project permission to set issue level security?
Best regards,
Marko Blagus
Alexey Kropotkin
December 6, 2023
Hi, I confirm to have the same bug.
  • Jira Cloud
  • Company-managed project
  • Business project
  • Issue security: Reporters,assignees&watchers (default)
  • Permission helper: Status:Alexey Kropotkin has the 'Set Issue Security' permission
P.S. Bulk change works fine
Like # people like this
MonaS
November 18, 2024
Hi @Michelle I truly apologize for any inconvenience this may have caused. This has already been addressed in Bug https://jira.atlassian.com/browse/JWMCLOUD-662.
Zuzana Toulcová February 20, 2024
Hi, @Marko Blagus
Is there any development to this Question?
Thanks, Zuzka
