Trying to add attachments in jira issue using rest api but getting [] in body from nodejs.
Jeet
April 11, 2023
Here is the code for better understanding,
 const filePath = 'file.png';
  const stats = fs.statSync(filePath);
  const fileSizeInBytes = stats.size;
  const fileStream = fs.createReadStream(filePath);
  const formData = new FormData();
  formData.append('file', fileStream, { knownLength: fileSizeInBytes });
  const formDataHeaders = formData.getHeaders();
  const response = await fetch(`${baseUrl}/ex/jira/${cloudId}/rest/api/2/issue/TEST-103/attachments`, {
    method: 'POST',
    body: formData,
    headers: {
      Authorization: accessToken,
      Accept: 'application/json',
      'X-Atlassian-Token': 'no-check',
      ...formDataHeaders,
Naveen Kumar_Appfire
April 11, 2023
Jeet
April 11, 2023
Hi, @Naveen Kumar_Appfire, Thanks for your response, I followed the documentation, but I got an error: object is not iterable for FormData.
Well, I have found a solution that is working for me in Node.js without installing any additional library.
const formData = new FormData();    // no need to install for node 18.^ +.
const file = new Blob([fileBufferData]);  // creating a new Blob from fileBufferData
        // import { Blob } from 'node:buffer';
formData.append('file', file, filename);   // second parameter is Blob, third        // parameter is filename.
const url = `${baseUrl}/ex/jira/${cloudId}/rest/api/2/issue/${issueKey}/attachments`;
const options = {
           method: 'POST',
           headers: {
                 'X-Atlassian-Token': 'nocheck',
                 Authorization: accessToken,   // `Bearer ${token}`
options.body = formData;
const response = await fetch(url, options);
return response.json();
FREE
