Turn off JIRA create issue inside of confluence
Chris Wood
I would like to turn this feature off when you highlight text in confluence - can anyone point me to the configuration? I cannot for the life of me find how to disable this feature.
Image below describes what I would like to disable.
Chris
Chris Wood
I ended up using CSS to hide the buttons...
Chris Wood
I ended up using CSS to hide the buttons when you highlight text...
Mehmet Kazgan
March 27, 2014
Totally smart!
Mehmet Kazgan
March 24, 2014
Hi Chris,
Then I think it might be an issue where OnDemand version might be overwriting the global template macro changes. I would create a support ticket.
Sorry, I could not help more.
Mehmet
Chris Wood
Thanks for your help - I am using the download version - I'll play around a bit more before opening the request.
Thanks again
Mehmet Kazgan
March 24, 2014
Hi Chris,
You removed that in Global Template and saved, right? Because I just tested it on my installed version and macros are disabled. Just to verify:
  1. Verify that you removed the Macro in the Confluence Admin>Prod Req Global Template and save
  2. Create a new Prod Req page and test.
See my screenshot in the GLobal Template:
Chris Wood
Hi Mehmet,
Yes, I removed the title in the global template as you indicated. Click on title, hit remove, save.
When I highlight text in a space the two icons still display:
- quote in comment
- create jira issue
Here is the global template screenshot.
Mehmet Kazgan
March 24, 2014
1. Go to Confluence Admin
2. Go to Add-ons
3. Click on "Global Templates"
4. Edit "Product Requirements"
5. Click box under Requirements>Title where it says "Short identifier...."
6. Select "Text"
7. Save.
Chris Wood
Hi Mehmet,
The box is already set to 'text' - any thoughts?
Chris
Chris Wood
image below
Chris Wood
image below
Mehmet Kazgan
March 24, 2014
Hi Chris,
It seems like it still has the macro running. Can you try to "remove" and save?
I do not have an OnDemand env to test, but that might work.
Mehmet
Chris Wood
Hi Mehmet,
Still showing after removing...
Chris
