Two boards on the same project
Shani Kovalsky March 16, 2016
I've created 2 boards in the same project using a filter.
I can see both of the boards here:
image2016-3-17 10:36:52.png
But other people in my team can only see the first board that was created. What should I do so all the team can see this board?
Thanks!!
3 votes
Phill Fox
 In the second board you need to share the filter and the agile board with your team. Click on the config board option and look at the general settings. Here you should see the current sharing. From which you can add others to the list.
Shani Kovalsky March 17, 2016
Got it! Thank you so much for your quick reply!!
