×Can I install two certificates on JIRA for two different domains on a single instance?
I wouldn't serve the same JIRA instance on 2 different domains. You'll get some weird behavior (and JIRA complaining) on the front end. Dashboards will def. complain.
Application links will probably have some additional problems too
Can you expand on the use-case? Daniel Wester is correct: This would cause broken behavior for functions that rely on the Base URL to achieve the right link.
