Two certificates on a single JIRA instance for two different domains?
Luke Adams
August 20, 2015
Can I install two certificates on JIRA for two different domains on a single instance?
Daniel Wester
August 20, 2015
I wouldn't serve the same JIRA instance on 2 different domains. You'll get some weird behavior (and JIRA complaining) on the front end. Dashboards will def. complain.
Paulo Hennig
August 20, 2015
Application links will probably have some additional problems too
Steven F Behnke
August 20, 2015
Can you expand on the use-case? Daniel Wester is correct: This would cause broken behavior for functions that rely on the Base URL to achieve the right link.
