UI problems after migration to Jira Data Center
Kseniya Krulova
February 6, 2023
Hello everyone!
We faced with the following UI problems after the migration to Jira Data Center 9.5.0 from Jira Service 8.14.1:
1. when we open attachment in the issue, all buttons (download/close) hides behind the Jira header and to download the file we need to zoom out the browser.
2. a similar situation occurs when opening a window when we transition issue between statuses - we need to scroll to find all fields to fill in.
Has anyone encountered a similar problem and knows how to fix it?Problem1.pngProblem2.png
Earl McCutcheon
February 17, 2023
Hello @Kseniya Krulova ,
Thanks for reaching out, and in this case, we will need to dig into the problem a bit deeper and will require sharing details about the site that are not suited for this public forum, So I have created an internal support request on your behalf to get you in touch with our Migrations support team to help out.
Please go to the following link for continued communications and add as much detail as possible surrounding the errors you are seeing and one of our support teams will assist you shortly:
I would recommend a good starting point is to generate a HAR file while loading the pages that are erroring as described in the following KB article but make sure not to add this file to this community thread as it will contain detailed information about your site that should not be on a public forum, only add this file to the support request that is linked above:
Earl
