I'm having a problem with the UPM and Jira. Please look at the screenshot attached. This happens with everything that I want to update. The plugin, however, does upgrade with no problems but I must stop my jira and start it again. What can I do to fix this?
Carlos
Unofficially, I'd test it out right away (of course during a maintenance period). If it's good for the goose, it's good for the gander.
Carlos,
Please review this page:
https://confluence.atlassian.com/display/JIRA/Integrating+JIRA+with+Apache
Especially the line related to configuring the proxyname for your server.xml:
proxyName="your-front-facing-domain.com" proxyPort="80"
Hi John,
That did the trick! Thanks!!!
I wonder if I should do the same for Confluence and Fisheye. Though they are not presenting any issue after the upgrade. It was only Jira who was being a brat.
Carlos
Hi Carlitos,
I'd already seen this error. Generally it is related to:
1) Apache/IIS proxying connections to JIRA;
2) Incorrect baseURL configuration;
3) Incorrect SSL configuration.
Would you check this three points?
Another thing that it is not clear for me: Have you upgraded JIRA recently? Has UPM worked in previous JIRA versions?
Best regards,
Lucas Timm
Hi Lucas,
I recently upgraded both.
I haven't changed my base url. I am using Apache Virtual Hosts (to hide the ports from my Ubuntu Linux). Nevertheless, everything was working well before the upgrade. I also have Fisheye and Confluence in the same box. And those work perfectly. There seems to be an issue with UPM/Jira combination.
Not really sure where/what to look for.
Carlitos
What does your Jira logs show you? It could be related to a plugin that needs to be updated as an another possibility.
I don't see anything related to the plugin. I tried the log scanner and I get these:
<th>Problem</th><th>Matches</th>Quick Searching for Issues Fails | 14 matches, last match on line 14172 |
Emails containing attachments with non-ASCII names lost | 56 matches, last match on line 13215 |
JIRA Stops Creating Issues from Emails | 5 matches, last match on line 11682 |
Workflow error: Cannot find Screen with id 'xxxxx' | 1 match on line 8652 |
Hercules throws a java.util.regex.PatternSyntaxException when scanning the logs | 2 matches, last match on line 5390 |
After upgrade to JIRA 5, Activity Stream or Gadgets no longer work | 1 match on line 5373 |
I have to say that these are really old though and would consider them resolved.
I also updated all plugins but all of them seem to work. I did have to stop and start Jira for things to work though.
Carlos
